I tried to convert some NTSC DV footage, which was captured thru premiere, to divx using Virtualdub, but I couldn't get satisfactory result. Seems like virtualdub doesn't handle the fields right. When there is movement on the scene, there are horizontal lines on the edge of the object (fields are off?). Even if I played the footage in virtualdub, it looked the same. The footage plays fine in premiere. Any idea? Thanks a lot!
well if your converting to divx, and you plan on viewing this video only on the pc, then you will need to deinterlace. I recommend a area based deinterlace plugin for virtualdub...
http://home.bip.net/gunnart/video/#deinterlacearea
If your using divx 5, the codec will deinterlace for you. Just make sure you specify that you're using interlaced material.
I will not eat oysters. I want my food dead - not sick, not wounded - dead.- Woody Allen
fonoop.com
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 06:10 -
Problems with Documentary trying to use both PAL and NTSC footage
By Lucy in forum MacReplies: 5Last Post: 24th Jun 2008, 15:57 -
Capturing PS2 Footage Into VirtualDub Help!
By CosmicOutburst in forum Newbie / General discussionsReplies: 1Last Post: 27th Nov 2007, 06:36 -
Problem converting HD footage into NTSC...
By Nilfennasion in forum Authoring (DVD)Replies: 18Last Post: 4th Nov 2007, 23:09 -
Encoding DVD to play NTSC given original footage shot on PAL
By ivo in forum Authoring (DVD)Replies: 7Last Post: 15th May 2007, 09:10
Statistics
Newest guides
Latest tool updates
New media comments
