Hello
I have the impression (please correct me if I am wrong) that the cheapest way to edit video is to do it in "raw" video rather than MPEG2 video.
Therfore I think of capturing my s-vhs recordings to AVI and convert them to MPEG2 in order to archive the video in high quality.
In the future I will pick up the unedited MPEG2 video, convert it back to AVI format, edit it and produce DVDs.
(I am in the process of finding equipment and method for a high quality archiving method and have not bought any equipment yet.)
Will the above mentioned method result in high conversion losses when converting AVI-files to MPEG2 format and back to AVI again (and converting to MPEG2 after editing)?
Please suggest better methods for high quality archiving for future editing.
My priorities are
All advices are appreciated
yes, whenever you change the file format your losing quality. if you want to edit it then capture it in avi, since mpeg is harder to edit.
if you want it in mpeg2, then capture it in mpeg 2.
id recommend capturing it in avi, editing it, and then convert to mpeg2. to lost as little quality as possible.
AVI to MPEG2 Conversion Software
By cyberboy in forum Video ConversionReplies: 3Last Post: 7th May 2009, 20:54 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 06:59 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 06:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
AVI to MPEG2 conversion
By Alexstarfire in forum Video ConversionReplies: 8Last Post: 6th Aug 2007, 18:42
Statistics
Newest guides
Latest tool updates
New media comments
