I am recording MPEG2 files (for DVD) off my AT TV-wonder. I have found VirtualDub suitable for removing commercials from my DivXs but it doesn't support mpeg2. I have tried a number of editor (tmpgenc and mpeg-vcr are the ones I remember) however none of them can cut precisely, so I always get a either a few seconds of one commercial or a few seconds cut from the show. In addition, they can can only cut the file (instead of the ability to remove segments from the same file) and I have to join them later, but that is but a minor problem right now. I am looking for a tool that can perform cuts with sufficient precision (at least the ability to move back and forth by 10ms). Although maybe I am doing something wrong, please correct me if I am.
Try the trial version of Ulead Video Studio. It will edit MPEG-2 files, allow you to chop out the commercials, and save the rest as a single file. If you use the file as the template for the project settings, it won't re-encode anything but the frames adjacent to the cut.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Thanks, I'll check it out right now.
While we are on the subject, is there a software PVR that would allow commercial skip?
VideoRedo: Can't save format with commercials cut
By DarkPhoenix77 in forum Video ConversionReplies: 11Last Post: 19th Sep 2011, 11:39 -
Software TV Studios use to edit/cut splice logos & commercials etc....
By Moontrash in forum EditingReplies: 11Last Post: 14th Oct 2010, 22:52 -
Using Mencoder to Cut Commercials from TS/TP fils not working
By Randall_C in forum Video ConversionReplies: 0Last Post: 3rd Jul 2010, 16:47 -
looking for tool to cut commercials then rip closed caption of ts file
By hunk in forum DVB / HDTVReplies: 2Last Post: 3rd Nov 2009, 18:22 -
Problem with script to cut commercials
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2008, 00:43
Statistics
Newest guides
Latest tool updates
New media comments
