has anyone bought a alba 113 dvd player form argos, if so what are they like???
I dunno but the alba DVD103 is quite good value - it plays VCD and SVCD and has a region hack available using the remote.
Forget that, go to http://www.empiredirect.co.uk and order the Pioneer DV-343 for less than £160.00 inc delivery. This little beauty will play ANYTHING, really well. Its not bursting with features but it's well worth the price. I just got one and I can't leave it alone, It has played every disk I've made (using Nero 5).
P.S. No I don't work for them
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
dont get the 113!i been hearing they dont play cd-r's!they can substitute the 113 for the 104(CHECK THE ARGOS SITE YOULL SEE)anyway i got the 104 its worked on everything ive tried,many types of cd-r &cd-rw's,plays mp3 nicely with fil display and folders.vcd work well-for such a cheap player it acts like a 200 pound job.i recommend it.
knoplix, argos claim the spec of the 103 and 104 are identical. so why have they change the number? anybody know? i assume its either to address the issue someone had of the tray opening and closing on its own, or to stop it being multi-region hacked. check and see if yours will work.
well it's ntcs/pal playback,the 103 hack didnt work.it isnt the same as the 103-that one didnt play as much.it must be macrovision free aswell as i have copied a dvd onto vhs no problem.another huge bonus!i ve now tried it with about 10 brands of media and have yet to have a problem.reads mp3's better then my portable mp3cdplayer.files,folder,random etc..havent had a track that skips and a few did on the standalone portable mp3player i have!
i got it mainly for vcd's and im sold!
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 11:44 -
Transfering audio signal form audiotape player to PC
By 1234567 in forum AudioReplies: 13Last Post: 7th Dec 2008, 14:20 -
So I bought a Philips DVD player that plays DivX files, but have a problem.
By quitearush in forum DVD & Blu-ray PlayersReplies: 5Last Post: 13th Jan 2008, 02:25 -
Permanently delete files form VLC Player playlist
By SteveF22 in forum Software PlayingReplies: 3Last Post: 30th Aug 2007, 13:21 -
Will a US-bought HDTV display movies from my PAL DVD player
By aguinebe in forum DVB / HDTVReplies: 8Last Post: 3rd Jul 2007, 11:06
