VideoHelp.com Forum
Results 1 to 9 of 9
    I've got a G4 Powerbook. Do I need some sort of a thingie to view QT.mov files?
    I thought different (
    Dave
    all u need is simply quicktime!
    that is unless its encoded with any special coded, then u will proly need that particular codec, but just try QT first.
    I have QuickTime 5.0.2 Pro -
    The file is a .mov file and it plays just fine in 9.2.2
    In OSX I get a white screen but the sound plays.
    I get a message when the file opens saying that I may have trouble viewing the movie and that QT may need a component.
    Dave
    hmmmm... try this, while in QT and the sound is playing like u say, stop it and hit command-i in QT. tell me at least what it says under "Format" in the info box in QT Pro, post it here. then maybe i can help u out, well see what we can do!
    The original file was an .avi.
    I installed the 3ivx D4 4.0PRI extension into the QT Extensions folder so that I could view it and used DivX Doctor II to convert it to .mov. The sound was all screwed up in .avi and was fine after converting with DivX Doctor.
    The 3ivx D4 4.0PRI extension is in the 9.2.2 system folder but not in the OSX system.
    Not sure where I should install it in OSX
    Here's a snippet from the QT info:
    Format: None, Stereo, 44.1kHz, 16 bits
    3ivx D4 4.0PRI Decoder, 512x368, Millions
    Movie FPS: 23.98
    Regards,
    Dave
    yea, looks like u pretty much solved your own problem already! u just need to install the 3ivx D4 codec in HD/Library/Quicktime folder, and it may require u to reboot to OS9 if it doesnt let u install in X. this will let u play it in OSX. i had a pretty good idea u needed either 3ivx or divx. and as a note, u took a correct approach. many of the files encoded with these codecs like divx and 3ivx, u will need to doctor or fix it in some sort of way so it will play correctly on macintosh. hope that helps.
    I found an OSX version of the encoder in the 3ivx folder that I'd downloaded from their site, and all I had to do was drop it into the HD/Library/QuickTime folder, as you said. No reboot necessary.
    Thanks for you interest.
    Dave
    anytime, glad to help!
  1. something like Reclock on OSX??
    By svdf in forum Mac
    Last Post: 16th Dec 2011, 00:26
  2. mkvextract for osx
    By scarlac in forum Mac
    Last Post: 14th Jul 2010, 04:54
  3. mencoder wont convert the complete file, mov to avi|mov
    By bjornieB in forum Video Conversion
    Last Post: 19th Nov 2009, 07:42
  4. Replies: 1
    Last Post: 22nd Oct 2009, 08:38
  5. MP4BOX 0.4.5 for OSX
    By cvkB in forum Mac
    Last Post: 17th Oct 2009, 18:51
