I have been capturing ok from VHS with my ATI Radeon 7500. Suddenly I'm getting a slight scratchy sound on the captures. I've tried changing the cables, re-installing my soundcard on a different PCI slot, but to no avail...
Any ideas? I guess it might be something simple I'm overlooking.
Bok
edit: I'm using a soundblaster live 5.1 connected to the ATI card for sound btw
I noticed when I get scratchy audio, I load the file into Gold Wave. If the graph shows my audio as going off the chart, I use the noise reduction function to bring it back down.
It also seems to make the audio sound even clearer after I multiplexed the wave file back into the video. I also read in this forum that the problem may be caused by the recording line in is set too high.Hello.
regarding the volume, in Vdub I use the audio meter to set the gain. In MMC 7.6, I had to set the volume (and input) in the registry. The value that MMC set initially was too high. Let me know if you want more specific Registry key settings...
Cheers,
TJD
If you have a VIA chipset with SBLive, it might be due to the pci latency.
There is a VIA PCI latency patch somewhere at viahardware.com
Some good tips, I'd already tried the PCI latency patch which crashed the machine..
In the end, I pulled the SB live out of the machine and have fallen back on the on-board audio. This is not as good, but no scratchiness!!
So, I'm looking for a new soundcard, any recommendations? Thinking about a turtle beach one at the moment..
Bok
p.s. I tried that SB Live in another machine with the same results, so it's in the trash !
Here's how I solved it
Goto your volume contro panel(usually found in system tray near the clock)
Click files--> properties
An "Adjsut volume for" menu should come up, click on 'recording' and hiot ok, a new bar should come up with the volumes of each recording device. Use the device yer capture is using(usually either Line-in on ATI/all in wonder or Tv tuner audio. Adjust the volume contol down and try it. Keep adjusting it til you get something you like. It solved all scratchy problems with an ATI 7500
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 10:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
help with scratchy audio - howto mute a few seconds?
By realbrew in forum DVD RippingReplies: 3Last Post: 20th Sep 2009, 04:05 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
