I have all my source video encoded in MPEG2(720x480) format.
Can you answer the following. If I were to transcode my MPEG2(720x480 - DVD) file into MPEG2(480x480 - SVCD) with REMPEG would I lose quality?
If the answer is yes, do you know of another way to transcode more efficiently that what I describe above? Can I use TMPGEnc to achieve the same results?
Am I better off saving 2 output streams(DVD & SVCD) from the original AVI file going forward?
Regards,
-Joe
Any time you MPEG an MPEG it is going to degrade. I'm sure there are varying degrees that you'll see the degrading, but a lossy compressor is lossy.
Your idea of making two different outputs from your original AVI is a good one and will most likely yield the best results. Many will think I'm crazed, but I make up to four different versions of each edited AVI I create. A VCD version for compatibility, a low bitrate CVD for my Pioneer DV-440, a max bitrate SVCD for friends with machines that can play them, a half D1 for DVDs of VHS, and a D1 version for DVDs of good sources.
need MPEG2-PS stream analyzer/reader
By amitchawla in forum Video ConversionReplies: 0Last Post: 10th Jan 2012, 01:16 -
MAC: Mpeg2 to DV Stream
By case 5 in forum MacReplies: 11Last Post: 7th Mar 2011, 13:42 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 14:10 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
Statistics
Newest guides
Latest tool updates
New media comments
