VideoHelp.com Forum
  1. I just recently purchased the above card, and am having some issues with the tv-out: it's in black and white. I'm using the composite out after the s-video adapter included with the card and can't seem to fix it.
    I can't test the card with S-video because I don't have any s-video components to test it with :/.
    If I use TVCC and up the color carrier, it does go to color - but I would like this to be a perm. thing so I don't have to use TVCC all the time. (That and since it seems to be out of development).
    I'm wondering if I should return the card and ask for a new one to see if it's just the card, or just deal with it or if there is another solution.
  2. Bah, what kind of TV do you have? PAL or NTSC? If the card is set to the wrong mode, you could get a B&W picture, or it my not sync at all, heh.
    Try looking for a utility to change video mode to match your TVs... I forget what's it called, but it's over at DVD Digest somewhere, in the geforce specific section, which I think is http://www.dvd-digest.com/nvidia/
  3. I was going to edit the post to mention this, but figured it wouldnt matter. Guess I was wrong. It's and NTSC TV.
    I tried PAL/NTSC/ETC. All possible modes, etc. using the standard drivers. SO it's def. not that.
    <font size=-1>[ This Message was edited by: Necromancyr on 2001-07-02 12:30:09 ]</font>
  4. I had the same card and the same problem. Its not the TV Mode -- its the SVHS to composite converter. If you use the composite to svhs converter ( that come with some video cards) as a svhs to composite it comes out as b/w because the luminance (color)is carried in a different way (I forget how). Go to radio shack and get a $20 svhs to composite converter. Or get a long svhs cable.
    <font size=-1>[ This Message was edited by: suspect on 2001-07-02 13:25:48 ]</font>
  5. Hrm, well the card HAS a Svhs-->composite convertor. I take it you mean that convertor is screwed right? There is no composite out on the card, need to use a convertor.
  6. yeah you need to buy a new svhs to composite converter.
  1. "Greenish" Black & White To "True(r)" Black & White?
    By DeathStalker77 in forum Restoration
    Last Post: 30th Jul 2011, 08:39
  2. black and white
    By foofie131 in forum Newbie / General discussions
    Last Post: 24th Mar 2011, 21:15
  3. Black and White TV Output From Nvidia Geforce 8600 GTS
    By nicolasqueen in forum Media Center PC / MediaCenters
    Last Post: 24th Jan 2010, 17:40
  4. Black and White Insanity
    By craigarta in forum Video Conversion
    Last Post: 12th Nov 2009, 09:22
  5. Do you take black and white photos at all?
    By yoda313 in forum Polls
    Last Post: 28th May 2008, 07:58
