I need some help with my new transcoded m2v and ac3 file. I tried re-muxing my old vob file with my transcoded m2v file, and that didn't work, so I just used SpruceUP to combine the m2v and ac3 file. That worked fine and dandy, but SpruceUP automatically puts my Dolby Digital 5.1 at stream id x80. When I need the stream at x81, because im keeping my movies menu and extras intact. I tried using VOBrator to change the id for my vob's, and for the first one it worked perfect, but for the rest of the movies vob files it doesn't even recognize it as dolby, and refuses to allow me to change the id when i select the audio stream. So does someone know a program that will let me mux my m2v and ac3 file and tell the program to put the ac3 file as a second source instead? Or maybe another program to change the id. Thanks for any help!
Thread: Wrong Audio Stream ID
I had the exact same issue, and the exact same problem with VOBrator (which is known to be quite buggy)
I ended up using vStrip to remap the audio to 0x81 so the disc would play normally (Fantasia which used DTS as audio1 and DD5.1 as audio2 which is what SpruceUp had created as audio1). vStrip is a command based utility but usually you can download it with a GUI and it will do the same as VOBrator for you.
Hope this helps.
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Getting wrong audio stream with VOB2MPG Pro 3.2.2000
By mwebb in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 20th Aug 2011, 13:45 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Why does my DVD start at the wrong stream?
By takearushfan in forum Software PlayingReplies: 0Last Post: 22nd Jan 2010, 18:16 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
Statistics
Newest guides
Latest tool updates
New media comments
