Hi,
this is my first post here.
The problem is to burn DVB stream into dvd whitout encoding.
The stream is in mpg format and audio @48.000 Khz.
No problem with streams @ 704 x 576 (pal), the authoring software create a perfect iso dvd image (without encoding video).
I've some problems with 480 x 576 video streams and audio @ 48.000 Khz. This is not standard resolution for dvd and dvdpatcher doesn't work perfectly.
I've patched the stream with dvd patcher, last version, (entire file, header only doesn't work) then add the video and audio (demuxed) and patch again for right resolution but fails to create dvd image...
Thanks for help.
hi Darkio,
What software do you use to authorise the DVD.
If have a Siemens/Fujitsu DVB-S card and I use ProgDVB to record the broadcast. I recorded in mpeg but when MyDVD software it took ages to convert it. Then someone sugested to record in PVA format convert this with PVAintr... to mpv and mpa and the authorise it with MyDVD this goes a faster (2hour dvd in 1 our to a DVD (PIII@667Mhz Ricoh MP-5125A)).
Do you have a faster way???
Hi,
I also use ProgDVB for capture and MyDVD for authoring. Problem is that MyDVD will accept full D1 no probs, but when I get a 576x544 it takes a while to process but the file isa massive. It works ok on standalone and ps2, but think that audio is pcm (hence big file). Am trying to use Spruc and TMPGEn to get smaller files (as these will compress audio) as currently it has to go onto two 4.7 disks. Currently I record in pva, then use Instrument o to conv to mpeg2, then feed into MyDVD. Any thoughts on how to feed into Spruc as it says is invalid format. Probably due to 576x544 and its not full D1. Any thoughts.
Maze
No dvb-s signal from satellite and Asus My cinema es3-110 card
By mammo1789 in forum DVB / HDTVReplies: 4Last Post: 28th Dec 2011, 17:13 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / HDTVReplies: 1Last Post: 19th May 2011, 05:38 -
Convert DVB-T MPEG4 H264 stream
By rocka in forum DVB / HDTVReplies: 14Last Post: 5th Aug 2010, 05:12 -
Stream DVB-S to media centers
By sal88 in forum DVB / HDTVReplies: 2Last Post: 31st Dec 2009, 11:03 -
Looking to build a PC to stream from Satellite to PC..
By MagikLair in forum Media Center PC / MediaCentersReplies: 0Last Post: 1st Dec 2009, 13:15
Statistics
Newest guides
Latest tool updates
New media comments
