VideoHelp.com Forum
    Hi,
    I have a little problem, it seems that my dvd-rom won't play dvds anymore. Apparently it happens only with new dvds. I have a Toshiba DVD-ROM SD-M1402. When I want to play a dvd with Power dvd I get the following message :
    ESDI driver or ASPI manager is not compatible.
    For controlling DVD-ROM, two system drivers will be used, that is, ESDI driver and ASPI manager. Older versions of ESDI driver have compatibility problem with DVD-ROM. ASPI manager might be replaced by an incompatible version if you install a SCSI device.
    I've tried with other programs and nothing seems to work.
    Any help would be greatly appreciated.
    Valerie
  2. You might have installed a player or burner that *%&(¤# up your ASPI.
    Uninstall everythingyou don't use and stick to one or two players and one or two burners.
    Then reinstall your Toshiba! ...might work.
  1. DV won't play correctly anymore.
    By xtremeD63 in forum Software Playing
    Last Post: 9th Apr 2011, 13:08
  2. DVD player does not read DVDs anymore, CDs - OK?
    By unixoidal in forum DVD & Blu-ray Players
    Last Post: 9th Sep 2010, 02:34
  3. Windows Media Player Won't Play DVDs Anymore
    By Card Shark in forum Newbie / General discussions
    Last Post: 14th Feb 2010, 18:04
  4. Can't play PAL dvds on my region free player anymore
    By bubblefaerie in forum DVD & Blu-ray Players
    Last Post: 12th May 2008, 09:51
  5. Replies: 4
    Last Post: 9th Sep 2007, 04:20
