I created 4 or 5 videos using Videostudio6 and encoded (in VS6) them as DVD mpeg-2 NTSC (720X480) format to put on a DVD-R. When I try to add them into Spruceup for autoring it tells me invalid file types. Anyone know what the problem might be? For the hell of it I tried to run those MPG files through TMPGenc and reencode to see if Spruceup would then take them. I ended up with no audio. I would like to find out why my original encodes aren't accepted but failing that why do I lose the audio on the reeencode on TMPGenc? Thanks.
Does this post give you any hints:
"Whats the quickest way to convert my svcds > dvdr ?"
http://forum.vcdhelp.com/viewtopic.php?t=100090
What is the file extension on your video file? Is it .m2v? If it isn't, rename your video file with the m2v extension. (Ex. Movie.m2v). Also, if you want the audio, the filename needs to be the same as the video filename.(Ex. Movie.ac3). Hope this helps.
Cooly-o,
Am I correct in assuming that I need to convert from 44.1 to 48khz for Spruceup to accept the files? Does Demultiplexing seperate the files into to components (audio &video)? Then convert the audio then multiplex the files back together? Is this right?
jslombar,
I'm not quite sue what you're saying. The files that I get from VS6 are *.mpg What would changing them to m2v do? Spruceup is supposed to take *mpg files. Also could you explain that last sentence a little more. What filename are you referring to? Thanks.
yes the audio should be 48Khz.Originally Posted by str1der
You should inport as elementary streams (quicker than mpg) with names
myfilm.m2v
myfilm.mpa
or
myfilm.ac3
the audio will then automatically get added.
I find spruce handles files very well.
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum CapturingReplies: 17Last Post: 20th Nov 2011, 03:51 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
help with Ulead videoStudio?
By wamit in forum CapturingReplies: 4Last Post: 24th Apr 2009, 08:27 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 10:23
