VideoHelp.com Forum
    .....into 2 equal video files?
    Is there a free program that will do that?
  2. Do a search on "Splitting Files"; there are heaps of ideas on how to do it.
    Regards,
    Joe.
    Yes,
    I found some things like bbmpg.
    I'm new at this and looking for the easiest and simplest way without trying them all. Could you please tell me which is the easiest? Please?
    Do I always have to encode? Or is there one that will just ask how many parts or Meg in each part, and just do it?
    I'd appreciate your thoughts
  4. The TMPGenc encoder will do it for you automatically. When you open TMPGenc, select File, MPEG Tools and there is an option to sepecity file sizes. I cannot be exact at the moment because I am not in front of my home PC; anyway, It is definitely there. Thanks.
    Regards,
    JOe.
    Jmaruca,
    Thank you. I found the instructions on the EDIT area of this site.
    I'm trying to figure them out now.
    thanks
    I was just now looking at TMPGenc's message forum, and noticed that they say TMPGenc has old issues with dropping some or all of the sound on one part of a file it has divided.
    Has anybody noticed that?
    Gosh, if a TMPGenc Rep. says that, does anybody have a suggestion of another file spitter that works well and easy?
  7. TMPGEnc really does have a problem with the splits having a little bit of the end audio cut off. I thought at first that I was doing something wrong but I've tried numerous attempts at cutting the same SVCD mpg file and it still gave me the same results; and now reading that it's an official problem, I personally wouldn't recommend cutting with TMPGEnc.
    Is there a freeware program you would recommend?
    that is easy and effective?
  1. cannot burn or copy captured mpeg2 files
    By DirtBikeMike in forum Capturing
    Last Post: 3rd May 2011, 07:49
  2. How to split and edit captured video
    By perinet in forum Video Streaming
    Last Post: 22nd Nov 2009, 09:40
  3. Split MPEG2 at exactly time !
    By *Baby* in forum Editing
    Last Post: 25th Sep 2009, 10:06
  4. Captured AVI frames broken/split/badly aligned
    By cyclometric in forum Video Conversion
    Last Post: 25th Sep 2008, 07:50
  5. SVCD / MPEG2 - bad packet stops file.
    By Steve Walsh in forum Authoring (VCD/SVCD)
    Last Post: 9th Jul 2007, 12:03
