What would be, if possible, the best way to convert a svcd/vcd to fit on a 64mb MMC card to be watched on a Pocket PC. So I can watch a film when out and about![]()
Thread: Pocket PC
..........and....er...is this thing on ?
So you want some method of converting a 700Mb file to fit into 64Mb MMC card ?. If you find a codec to do that, let us know... We will all want it
You can fit a movie about max 100 min into 128MB Card with the divx codec (4.12 or divx5 codec) with good quality.
But you need some settings,change framerate, Audio
I have made a guide how to,but it is in german!
Take a look at it
http://www.chaossoftware.ch/pocketpc...divx/index.phpAMD XP2000,ASUSA7V333.GF3 V8200 TI200,
Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV
I very much doubt this, if the original was a DivX DVD rip, it would be good quality at 700Mb +. half of that size would be 350Mb, by now the quality is nowhere near the original, half again 175Mb and the quality is now bad, get down to 128Mb well I would not even call it a movie.with good quality.
Also the original post says 64Mb, so I guess you are saying he should now get a 128Mb MMC card ?, and lern German if he does not do so now
I have a Movie Player on my Sony Clie (which uses the PalmOS) and it came with a software package called Picture Gear, which converts AVIs Mpegs etc to a special Palm OS format. Pretty cool. I use it to dump short clips etc to my PDA (ie 30min or so in size).
The Clie runs a resolution of 320x320 so the quality aint great, but its very entertaining.
Best Regards
Amelia
Sorry but i have made the guide for some germans pocket pc sites.
But you can take a look at the pictures.Iám nit currently planing to translate this guide,because i have not much time yet!
With an 64MB multimedia card,its not possible to take a full movie on it with good quality, but a 128 MB is enough.
and yes the quality looks good,and the newest alpha player supports divx5 encoded movies,with B-frame support.
I am have a Casio EM500 machine,and it has enough power to play the files, at 320x240 full screen, and mono sound. But the framerate must be changed to the half size,when you have a Strong Arm machine it has enough power to play full framerate, and a resolution about 320x176 (16/9)
In my guide i use Virtual Dub to re-encode my divx movies but you cab also load standard mpeg1 files in Vitual Dub.
You can use some great filters,to made the image quality look better,at lower bitrates.
I usually use, a the divx 2 pass modus,so you can get lower file size and better quality.
For action movies a bitratze at 250 kb/S max is enough
And for the Audio use mono 32 kb/S (its enough)
The Image Qualitylooks really good,on the smale screens,no very less makkro blocks.
I dont know if somebodys has made a english guide,but i am a german,(Austria) we are all pocket movies fanats,and so a have made a guide and this takes me a lot of time,for best settings.
What pocket pc machine did you have.
Give me your email,and i´ll will send you a short test movie from the film
dripple X (XXX).
Or you can email me Jaspa21@gmx.at
I am also a beta tester form the pocket divx player,(thanks to gottahavit and marc pedro for the mips optimized version)
You can get the latest players from there
http://home.adelphia.net/~mdukette
cu Jaspa 8)AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
But i you dont want to buy a new SD oder MMC card,you can try Windoes _Media encoder7.1 to get the movie on your 64MB card and so you have a WMV file.
But that gives bad quality,because the microsoft encoder,does compress the files too much,and a lot of details are lsot than.
Give pocket divx a tryAMD XP2000,ASUSA7V333.GF3 V8200 TI200,
Help please, easy format pocket camcorder?
By Lilygrace in forum Newbie / General discussionsReplies: 14Last Post: 23rd Aug 2010, 12:04 -
safe few bucks from my pocket
By mrdin2005 in forum Video StreamingReplies: 2Last Post: 20th Jul 2009, 04:26 -
Fujitsu Siemens Pocket LOOX
By mgowins in forum Video ConversionReplies: 2Last Post: 9th Jul 2009, 16:09 -
Movie player for Pocket PC??
By Cazz in forum Software PlayingReplies: 2Last Post: 2nd Jul 2009, 15:39 -
Is my Passport Pocket USB 2.0 dead?
By htp367 in forum ComputerReplies: 5Last Post: 23rd Aug 2007, 14:15
