VideoHelp.com Forum
    Well, I downloaded a few divx movies from sharereactor. the downloaded files are AVI's...and DIVX. A few of them are JUST barely over 700 MB. One movie is 702 MB and another is 701 MB....just enough that they will not burn to a 700 MB cd.
    So I was thinking I could CROP off a few seconds and make it fit. I have used TMPGEnc and Virtual Dub quite a bit, and have tried to figure out how to use either of these programs to accomplish what I want. I got close but I didnt get exactly the right thing. The AVI that resulted from using Virtual Dub was alot worse quality, even thoguh I only chopped off 10 seconds. It was also 150 MB smaller.
    All I think I need to do is crop a bit off the AVI and RE-Save it, using all the original formatting and DIVX encoding and Audio encoding. Is there a way to do that?
    Thanks. [/u]
    You can burn a little more then 700MB on an 80min/700MB cd in Mode1 if im not mistakin a 700 meg disk can hold 703.1Megs try burnin the original file and also you could overburn if it doesn't fit
    I don't know i could be wrong if i am im sorry
    Thanks for the reply. I did a tiny bit more research and immediatley found the guide I needed.
    http://nickyguides.digital-digest.co...-split-avi.htm
    Basically I had tried doing this before, but took teh Projected File Size reported by Virtual Dub a little too seriously.
    Apparently, it goes down as it saves.
    Anyway. I chopped off the last 10 seconds re saved it as an AVI an got a 699 MB file.
    :P
    I really am a newb, huh?
    Well im happy you've got the guide you needed.
    And everyone has to start somewhere we were all newbies once
    also.
    try other cd-r media.
    i have a boatload of sti-digital media brand cd-rs that are 80min/703mb.
    you can find them at any circuit city yo.
    THIS IS HARDCORE
  6. A good trick is 2 make an ISO or IMG file of it using cd creater 5 platinum then burn directly from the ISO. This will force CD Creater 2 "overburn" the data on the CD. Most 700MB cds can hold about 703-708megs.
    Thanks. [/u]
  1. 800mb avi; Would want it to go onto a 700mb CD
    By mark63534 in forum Newbie / General discussions
    Last Post: 28th Feb 2010, 19:31
  2. Blueray to a 700mb .avi file
    By withmenilu in forum Blu-ray Ripping
    Last Post: 24th Jun 2009, 05:07
  3. Shrinking an AVI file from 1.4GB to 700MB
    By DVantrease in forum Video Conversion
    Last Post: 28th Mar 2009, 19:11
  4. bitrates for 650-700MB AVI to DVD
    By ecc in forum Video Conversion
    Last Post: 20th Aug 2008, 18:26
  5. 900mb avi to 700mb vcd
    By dck42069dck in forum Video Conversion
    Last Post: 4th Mar 2008, 13:33
