i am using panasonic encoder 2.5 standalone and would like to know what odd and even field will do to the output mpg?
will it play smoother? also how can you make vcds look less blocky in tmpgenc?
Cheers
City Hunter.
Odd fields = field 1, and even fields = field 2. Field 1 plus field = frame 1. Also, odd fields, lines 1,3,5,7 and so on. Even fields, TV lines 2,4,6,8 and so on. In other words INTERLACED video. In the VCD standard, you cannot have interlaced video, so you can choose field 1, field 2, or the sum of the two.
As for blockiness in VCD's. Because of the low bitrate, you have to try to use every bit effectively. You do this by reducing all the video noise you have, and if that is not enough, then you have to reduce the detail in your video to give more bits to changes in the video instead of details. In Tmpeg, turn on the noise reduction filter. Then play with the three settings in that filter to give you best quality picture yet minimum blocks during action video. You have to use trial and error to find your best settings.
SK
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 5th Dec 2007, 23:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
