VideoHelp.com Forum
  1. hi i have a couple of home movies on my pc,i want to put them on my dvdr and play them on my home dvd player,but i tried and my home dvd player said please insert a difrent disk
    help.....
    Usually you would stuff an Avi onto a CD-R or CD-RW as a VCD movie which plays on most standalones.
    If you want to use a DVD, I think you can do the same so long as you have a VCD compliant stream. Use TMPGenc to create this stream (search on google for TMPGenc)
    Make sure the DVD-r disk you are using is of high enough quality to play movies on your standalone. Some of the $1.00 and below disks are nothing more than coasters for keeping your cup o coffee on.
    I use branded Verbatim and Pioneer disks for final creation.
  3. Member spidey's Avatar
    Assuming you have correctly and properly authored and converted your stuff to valid VCDs/SVCD's the problem may be your player.
    Check here for compatability in reading both your medium and format.
    http://www.vcdhelp.com/dvdplayers.php
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  1. Multiple avi movies on one dvd......portable dvd player that plays it?
    By 9tinyfingaz in forum DVD & Blu-ray Players
    Last Post: 6th Jul 2009, 03:56
  2. 5 Avi Movies to Dvd - Easiest Way Please?
    By Ruudboy in forum Video Conversion
    Last Post: 23rd Nov 2008, 20:39
  3. Replies: 6
    Last Post: 20th Oct 2007, 16:11
  4. 1h40min movies became 50min movies after conversion
    By oediv in forum ffmpegX general discussion
    Last Post: 31st Jul 2007, 14:13
  5. Converted analog film movies to BMP/JPG: now to AVI and then DVD
    By Wimpie44 in forum Newbie / General discussions
    Last Post: 1st Jul 2007, 12:47
