might sound simple to some of u ( i hope so anyhow ) but i have downloaded a movie .bin file and there isnt a cue file . It is a svcd as far as i can tell how would i go about burning it ???
thanx in advance
keep up the great work guys
extract the mpg using vcdeasy, determine whether it's mpeg1 or 2 (I use mpegproperties)-all programs available thru links on this site-and burn using your favourite programOriginally Posted by davie_zone
burn it in nero (load the bin instead of cue) or mount it in Daemon tools and do a disc copy.
Well, I am the slime from your video.
Oozin' along on your livin'room floor.
Alternatively, download a copy of Isobuster and extract the mpg or dat. Or use Discjuggler directly to burn the bin as an image file. Personally, I would extract the mpg from the bin first, and burn to (S)VCD using Nero.
scottymac
how do i extract the mpg using vcd easy i seem to have 'ripped' something xml file is this correct
thanx for your time again
The best way is to extract everything from the BIN file with VCDXRIP and then immediately rebuild the S/VCD with VCDXBUILD. This way, you regenerate the CUE/BIN image and can burn as per normal.
Both VCDXRIP and VCDXBUILD are command console tools but VCDEasy contains a GUI for both of them.
http://www.vcdimager.org
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
