Hi, My spec is this,
Cyrix3 650Mhz CPU,
320Mb Ram,
TNT2 Video Card (32mb AGP),
My system will not play a DivX and I have about 30 movies as well
Please can sombody advise......when i play a DivX movie the picture Lags behind the sound, it plays fine for about 2 seconds then freezes and then plays again for another 2/3secs then freezes again.....is there some kind of patch or some utility that can make it play on my machine? or have I set somthing up wrong or somthing?
Please can Sombody help me thanks.
Have you tried other players, which one do you use. I use media player but there are many more players you could try.
I can't imagine it being a hardware problem 650 should be plenty I have played them on 350MH and have had no problems
good luck.
I GIVE UP!
PC OUTTA MY WINDOW
Gavin,
One minor detail to keep in mind here is that the Cyrix 650 isn't what you'd call a high performance chip. ( No religious chip wars please
) Benchmarks have shown it to be a fairly capable business machine but mutimedia and gaming.....not so good.
I don't know what you're using as a player. Some of the made for DIVX ones can often do a better job than the Windows Media Player so it might pay to experiment with some of those.
Other than that, try a few of the optimization sites to try and tweak a bit more speed out of your machine. Seeing as DIVX is mainly CPU dependant, you may even want to look at overclocking. Note that this is not a recommendation. Only a possibility.
Good Luck.
Ian
16:9 divx movie won't play properly on my TV
By romino in forum Video ConversionReplies: 4Last Post: 22nd Oct 2010, 06:36 -
How do I play a movie in AVI format on my computer?
By tfly in forum Video ConversionReplies: 8Last Post: 11th Nov 2009, 02:56 -
DivX Player 6.82 cannot play AVI movie
By chuckycheese in forum Software PlayingReplies: 10Last Post: 24th Jul 2008, 22:10 -
Can you play HD Divx files only on computer?
By chin569 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2007, 11:19 -
dcr-sr42e movie cant play in computer
By meeya in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 12th May 2007, 15:25
