Divx is problematic. I installed 3.11 and it ran fine, until i installed 4.00 BETA, it still ran fine, but THEN i installed DivX 5 and the problems began. It's too slow, and in the 4.00 BETA works fine.
I don't know what seems to be the problem, if you know and know how to fix it please post and answer.
The CPU is an AMD 500 and with almost 4 Megs of Video.
Thread: Problems with Divx
DivX 5, not one I use to encode with, but it does work well. If you had Divx 4.12, V5 will overwrite it, as its not a DivX
Do you have DivX 5 Pro
I have the Normal Version
Well you might consider installing the Nimo codec pack, it will overwrite any codec's you already have if contained inside Nimo.
DivX 5 Pro is better
Apart from the rubbish player supplied.
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 13:00 -
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 10:04 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
Divx 2 DVD Problems
By KilinKind in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 08:03 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 00:26
Statistics
Newest guides
Latest tool updates
New media comments
