hi
i have a problem with the region hack for the daewoo dv-115. i know that there is a hack for this dvd-player. but when i try to apply this hack, it doesn't work. i make the following steps:
Remove any discs
Press Open/Close button on the front of your DVD (Open lid)
Press 8926
Wait for five seconds
Press 0
Wait for 15 seconds
Press Open/Close button on the front of your DVD (Close lid).
but each time i press 0 on the remote control, the player shows a little hand in the upper left corner on my tv screen. i can change to region 1-6 but i can't set my dvd to region free.
does anyone has the same problem?
i hope you can help me soon.![]()
cu
Results 1 to 1 of 1
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
How to change a Daewoo DSL-19M1WC TV/DVD unit from region 2 to multiregion
By gcatano in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Dec 2011, 01:06 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 18:18 -
Hack the Daewoo DS-K965
By sonquilombo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jan 2009, 18:08 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
