  1. Can ANYONE tell my how to fix the sound when converting a dvd to DIVX using DVDx. For some reason the sound is off by at least a second and the video is sketchy at times. I can convert to VCD perfectly. Im trying the next step and I need lots of help.
    P.S. on the DVD to Divx guide, they don't give any problem senarios so I can't figue the proplem Thanks!
    Austria
    Use the new DVDX2.0 version
    what codec did you use?
    I recommerd Divx5.02 Basic and the mpeg layer III radium codec (fraunhofer)
    or you just make the video file without audio stram export it to ac3 with DVDX2.0 open the generated AVI with Virtual Dub 1.4.10 and convert the export ac3 fileto a wave file using headac3towave and open this file in Virtual Dub and make a multiplexing,
    read the Virtual Dub Guide on www.divx.com
    Why does nobody can help with the DVDX Tool???????????????????
    AMD XP2000,ASUSA7V333.GF3 V8200 TI200,
    Alpha 8045,Y.S Tec Poer Fan, Seagate Baracuda IV
