Hi Everyone,
I have a whole bunch of questions and if anyone could help that would be greatly appreciated.
First off my specs:
p3
800mhz
87 gigs (27,20,40)
512 rdram
ati all in wonder pci
currently using composite to capture
MY questions are as follows
1) My ATI All In Wonder cannot cap higher than ___ x 240. Now I've heard several different solutions/reasons but I don't know what is true. I've heard that it is a glitch that doesn't allow the PCI card to cap higher than 240 and that it can be bypassed. I've also heard that 240 is the maximum it can cap at. Whcih is true? IF this problem can be fixed, how can I do that?![]()
2) S Video vs Composite: When capturing is it better to use S Video or Composite? What are the advantages/disadvantages? How much does cable length affect S Video vs Composite etc etc
3) Personally I usually cap using VirtualDub and use TMPGenc to convert from avi -> mpg. It usually takes me 40 minutes for around 25 minutes. By increasing processor or ram total, how much faster could encoding get? (In other words, what are the benefits in comparison to cost?)
4) I am currently interested in purchasing a new video card and I was thinking of getting one from the Geforce 4 Ti Family. I've read a few comparisons and it seems that the Visiontek Geforce4 Ti 4600 gives the best results. However it also states "NO Dual-Display DVI->VGA adapter" this is kind of a stupid question ubt does that mean that dual montiors are not supported or no dual digital -> analaog adapters? I'm not quite sure what this means.
Thanks!
Cooj 8)
Unless you have the older vfw drivers, the ATI all in wonder can't get higher than X x 240 capturing in AVI now.
Use the S-Video connector.
A faster CPU would shorten the encoding time in TMPGenc. You have plenty of RAM. Going from your 800 MHZ CPU to 1.6 Gig should cut your time by about 1/2.
Capturing VHS with ATI TV Wonder HD600 PCI card
By CamaroDMD in forum CapturingReplies: 12Last Post: 17th Jun 2010, 07:58 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum CapturingReplies: 3Last Post: 6th Nov 2009, 00:10 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum CapturingReplies: 3Last Post: 6th Sep 2009, 14:45 -
I have questions about this ati all-in-wonder pci-e card
By yoda313 in forum ComputerReplies: 0Last Post: 6th Sep 2008, 09:23 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum CapturingReplies: 2Last Post: 6th Aug 2007, 16:49
Statistics
Newest guides
Latest tool updates
New media comments
