VideoHelp.com Forum
  1. HI PPL
    I am quite new to all this so i was wandering if anyone could help me to put a dvd rip onto a cd to play on my dvd player. I am not sure what format it needs to be in. I have worked out how to convert movies from one format to another but the rest I have no idea about.
    Thanks Guys
    MENIKMEATI
  2. Get Slack disturbed1's Avatar
    Look directly to left of this page.
    HOW TO
    This how to will tell you everything you need.
    Here's the links just incase
    http://www.vcdhelp.com/burnmpg.htm
    http://www.vcdhelp.com/convert.htm
    BTW: Seems like alot of people are missing the guides, as most questions can be answered in there. Maybe there should be links at the top of every forum index incase someone missed it the first time around.
  3. thanks, I worked out how to convert the files and burn them to cd using nero. However i go to play them on my dvd player and I get a black screen and the timer runs faster than it should. My dvd is cd-r, cd-rw and vcd compatible. It displays that it is a vcd2.0. Is this problem in my dvd or the way i have burnt it, the file is mpeg-2 and i am doing it as an xvcd.
    Please help
    Thabks
    Menikmeati
    Since my dvd player can not play SVCD, I have to do a XVCD as well, when I want mpeg2.
    Video MPEG-2, any resolution, any bitrate, VBR or CBR.
    Audio MPEG-1 Layer-2 44,1kHz, any bitrate.
    multiplexed with TMPG as MPEG-1 Video-CD(non-standard).
    burnt with nero as Video-CD (leave "create standard compliant CD" unchecked).
  5. thanks heaps man
  6. thanks heaps man
  1. Burning some WMV and MKV files to play on a DVD Player
    By marnisper in forum Newbie / General discussions
    Last Post: 7th Oct 2011, 08:24
  2. burning divx files as data to play on dvd player
    By penguyen in forum Authoring (DVD)
    Last Post: 30th Jul 2011, 10:54
  3. Burning HDV AVI to DL-DVD to play on BR player.
    By suppafreak in forum Authoring (Blu-ray)
    Last Post: 6th Oct 2009, 19:25
  4. Replies: 8
    Last Post: 9th Sep 2009, 07:26
  5. Burning AVI file to DVD-RW to play on a Divx DVD player
    By Jay8284 in forum Authoring (DVD)
    Last Post: 5th Jan 2008, 14:03
