is it better to use software which converts straight to mpeg
i have just about an aver tv card, and the software i got with it
allows me to convert staight to mpeg 1&2, is this the best way to
covert, or is it better to use tmpge and virtual dub to convert,
any helpon this would be great as im new to all this.
cheers
edmond
email:
marc1@kelly1.fsworld.co.uk
Hi,
Chances are that TMPGE will give better quality encoding than any (non-Hollywood priced) real-time encoder could ever give.
Also, if you're going to do any editing or filtering then capturing at the least possible compression will minimize quality loss due to re-encoding.
Allan
Free software that converts mpg2 or DVD to avi (divx) ???
By szalaikornel in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 02:52 -
Want to play mp3 songs in my car's cd player-what software converts it?
By jbitakis in forum AudioReplies: 5Last Post: 10th Jan 2009, 08:59 -
Do you install software from the cd/dvd or go straight to the website?
By yoda313 in forum PollsReplies: 11Last Post: 18th Jun 2008, 14:10 -
what software converts to DVD with manual video bitrate control
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 12:09 -
Software that converts .AVI into PS3 compatible format
By dec60228 in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2008, 08:27
Statistics
Newest guides
Latest tool updates
New media comments
