hey i am trying to to change a bad quality vcd to better quality it is a one file movie and it is bad quality can u change it so it is 2 disc vcd
Thx
Gav
you can increase the bitrate so that it takes up more disc space but it will still look just as bad.
Garbage in = Garbage out
Thanks for that how do i make it a bigger file or turn it in to vcd so i can play it on my dvd and wat about sound is that the same or can i change the quality
Gav
look over to the left of this page. I suggest starting with the whatis section. When you have familiarised yourself with the various formats you can start on the HOWTO section, the convert guides are probably what you need most. If you still get stuck, search the forims for info and post questions here if all those methods fail to yield results.
You can do whatever you want to your vcd except maybe increase quality.
Polished Shit is still shit.
Run it through Cleaner if you want to get rid of some artifacts. But It will give you a slight blurred image.In this industry, Sadly, The future was yesterday.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
bad quality on youtube
By stansvid in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 20:57 -
Getting bad quality with AutoGK
By alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 08:37 -
Bad quality downscaling...
By Emillister in forum Video ConversionReplies: 33Last Post: 29th Aug 2009, 12:48 -
Bad quality with VobSubs
By Xavier in forum SubtitleReplies: 1Last Post: 19th Apr 2008, 02:31
