ok i got a cheap mintek 2110 player. i read the compatibility list and some say that it plays svcd's and some say it doesn't. then others say that if it cant play SVCDs then burn them as XVCD's.
my question is, why would it be able to play XVCD's but not SVCD?
also, when using nero or vcdeasy, how do u select XVCd for burning?
all i see is vcd and SVCD.
thanks
There is'nt a specific selection for xvcd. xvcd just means that it is a non compliant vcd. for example non standard resolution, bitrate or audio frequency. If you choose to create a vcd with nero and you get an error message which says that the file is non compliant, but you ignore the message and burn it anyway, the result is an xvcd.
Craig
I suspect that most VCD players will play XVCD's but plenty of (particularly the older ones) don't play SVCD's because SVCD is a newer format. XVCD's in some ways are better than SVCD's because a whole lot more players like XVCD's. You don't select XVCD. You encode a VCD at a higher (non-standard) bitrate in TMPEGnc.Originally Posted by jedi
Windows cannot see VCD, directory blank, but plays okay?
By ianlin in forum Authoring (VCD/SVCD)Replies: 8Last Post: 3rd Oct 2008, 15:17 -
It plays OK on the PC but not the DVD?
By thief_ in forum DVD RippingReplies: 4Last Post: 12th Jun 2008, 04:52 -
VCD plays but has no audio
By rockydogg97 in forum Newbie / General discussionsReplies: 1Last Post: 12th Feb 2008, 02:07 -
plays cd and not dvd
By london053 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Nov 2007, 07:26 -
Bilingual VCD plays both languages in Media Player Classic!
By cordeliamars in forum Authoring (VCD/SVCD)Replies: 2Last Post: 27th Aug 2007, 12:25
Statistics
Newest guides
Latest tool updates
New media comments
