I have tried sending my DV from my camcorder to my PC. I usually have no problems, but I need some advice.
The files are absolutley HUGE. A 30 second clip takes up between 150-250 MBs... No matter what format I convert the file into.
I would love to be able to take my home video, and save it to VCD. All VCDs I have hold about 30-40 minutes of semi high quality video, and would like to do the same with my camera.
Any hints on what I am doing wrong, or a program that will compress this better?
(I think I'm using Ulead and have tried a few others)
Thread: DV output to file...
VCDs have exactly 74 (or 80 depending on the disk) minutes of video and use MPEG-1 format. DV video has its own format and uses constant bit rate at 3.515 mb/sec, this is why your files so big.
Read 'How to' on the right. It contains answers to all your questions and instructions how to build VCDs.
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 07:04 -
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 23Last Post: 26th Jan 2011, 15:00 -
Have HD MKV file, would like HD output file
By StevoK in forum Video ConversionReplies: 3Last Post: 9th Feb 2010, 21:43 -
No file after encoding (No output file specified)
By Bizbo in forum ffmpegX general discussionReplies: 1Last Post: 25th Jul 2009, 04:17 -
By Bizbo in forum ffmpegX bugs and suggestionsReplies: 2Last Post: 24th Jul 2009, 20:24
Statistics
Newest guides
Latest tool updates
New media comments
