I have transferred a DV tape to my hard drive (62 min's about 13GB). I want to open it in Vdub so I can edit it, but when I try to open it I get the message.
Could'nt locate decompressor for format 'dvsd' (unknown)
Virtualdub requires a video for windows (VFW) compatible codec to decompress video. Directshow codecs, such as those used by windows media player, are not suitable.
I have installed the nimo codec pack.
I cant see any other codecs on this site that may be suitable. Can anyone tell me which codec I need to use and where I can get it.
Craig
You need to install Mainconcept DV codec from http://www.mainconcept.com. It is a commercial codec but
a demo version can be downloaded from their website.
PhArAoHWinners never quit, quitters never win. Those who never win and never quit are idiots.
Apparently that codec adds a watermark to the video, anyone know of free codec that does'nt do this.
Craig
In that case, you might try the following:
Make a new file with notepad and give it any name and make sure it has an AVS extension. On the first line type:
DirectShowSource("path to your AVI file.avi")
In VirtualDub click on file->open video->select the *.avs file you just created and then manipulate the video as you wish.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
Cannot open H264 video using VirtualDub
By kinlunyu in forum Video ConversionReplies: 12Last Post: 21st Aug 2011, 14:28 -
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2010, 14:37 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49 -
HD Video from VirtualDub to Premiere Pro for editing - What codec is best?
By gliebetronics in forum Video ConversionReplies: 6Last Post: 14th Jul 2008, 11:57
Statistics
Newest guides
Latest tool updates
New media comments
