Hi,
I have a Panasonic DVD-RP91 and when I try to playback a regular burned VCD it plays back in a slight slow motion. The voices sound deeper and abnormal, and the background sound is also slightly slower than normal. My VCD's play back perfectly fine on the computer both in my DVD-ROM and also my CD-ROM on multiple compters. It only plays back slowly on the DVD player. Can anyone tell me what might be wrong under the DVD player settings? I tried changing up the sound properties, but nothing worked.
Thank you,
Kristin
what are the specs (rez, framerate) of your VCD?
I do the frame rate at 352x240, 1152 kps. I basically followed the steps on the vcd help page on converting AVI's to MPG's with TMPGEnc. I also recorded digitally with stereo sound, 48 hz, at 192 kps. It sounds fantastic on the computer, but sounds slowed down on the DVD player.
Kristin
That's the symtom of n XVCD (VCD made with bit rate high enough that the DVD cannot handle).
Check your bit rate and the DVD player compatibility.
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
Movie slows playback like slow motion
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2010, 04:10 -
Need MTS Player with Slow Motion
By mightyjak in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 08:47 -
Video player recommendation needed for precision remind/slow-mo playback
By shinew in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2009, 12:38 -
Slow motion FX hangs DVD players
By Canopus Smoker in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2008, 16:18
Statistics
Newest guides
Latest tool updates
New media comments
