VideoHelp.com Forum
  1. i'm new at vcd etc. and i want to know if there is a way to make a high quality vcd . that's all.}
  2. if you insist on using mpeg-1, then xVCD would be the way to go (standard VCD 2.0 is stuck on CBR and bitrate of 1150, which is way too low for good quality)....however, if you adjust the resolution, bitrate, encoding method (cbr, cq vbr, 2 pass vbr)...then it would be xVCD
    another way to go is mpeg-2 svcd, which is generally better than xVCD and definitely better than VCD 2.0, but you have to make sure your standalone dvd player supports SVCD
    http://www.vcdhelp.com/dvdplayers.php
    Could you be a little more specific as to what you mean by "high quality"? Do you mean a VCD of the same approximate quality as the commercial, retail VCD movies that they encode with very expensive hardware? Something less than that? How much less?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    you can check out this link (below) here in reference to MY expeience
    with going the DV route.
    In addition, I have posted some sample clips there. D/L them and see
    or share your comments on them.
    LINK: DV Camcorder - R U using your's to capture?
    See you all later on this evening.
    -vhelp
  1. Replies: 6
    Last Post: 5th May 2011, 00:32
  2. How to make DVD movies in high quality
    By bell in forum Authoring (DVD)
    Last Post: 2nd Nov 2009, 08:42
  3. lower low quality online tv how to high quality :( :x
    By gorry563 in forum Video Streaming
    Last Post: 22nd Feb 2009, 06:56
  4. Replies: 2
    Last Post: 9th Feb 2009, 18:33
  5. Replies: 14
    Last Post: 23rd Dec 2007, 20:02
