VideoHelp.com Forum
  1. Hey all, new to the vdchelp forums.
    i couldnt find anywhere to put this post, so i thought id stick it here.
    anyway, my problem is that i want to put a avi/mpeg movies off my computer to VHS tape, i have a TV-OUT and was wondering if i could somehow record onto the tape through the tv-out.
    is this possible?
    and would i need any furhther hardware to do it. Thanks
  2. Yes, yes there is....
    Oh, you wanted to know how. Sorry. Just hook up the computer to your VCR via the TV out. Then, open the files so that they play full screen. I would suggest recording a few seconds before you start playing the video, so that the VCR doesn't cut it out. What you see on the computer & TV screen should be what your VCR is seeing, so remember to hide the mouse cursor.
    My shameless plug - XavierEnterprises.net
  3. Yes, should be no problem.
    Get a cable with a sound card jack on one end, dual rca out on the other (red/white), connect these to the audio out of your sound card and the audio in of your vcr.
    Connect the tv out of your pc card to the video in of your VCR.
    If you have dual screen capability, that s nice (ie you can display on both PC and output to VCR at the same time), otherwise you can hook up a tv to your vcr to check the output.
    If you have one of these Geforce 2 / 3 cards with tv/out, the card drivers do not have dual screen capability, you can check out the TVTOOL utility from http://tvtool.info/index_e.htm , it enhances the functionalities of the card.
    As for outputting:
    Start your VCR recording (make sure to select Video 1 as video source, or whatever name your video input goes by)
    Select the clip you want to play, start it with media player, press alt-enter to switch to full screen and make sure to hide the mouse pointer in one corner. That s about it really.
    You may find that the colors may be slightly washed out (depends on the quality of your tv out) or that the audio is slightly out of synch (can happen due to the fact that 2 sources are outputting audio and video separately), but normally it should not be a problem.
    I output my videos from my hard disk to my tv all the time, and mind you the quality is excellent.
    Cheers
    Arnaud
  1. VHS to DVD Recording - 4:3 VHS Becomes Widescreen on DVD
    By Ocracoke Pelican in forum Newbie / General discussions
    Last Post: 31st Dec 2011, 13:04
  2. Vhs to dvd recording
    By JAYHAWK1970 in forum Newbie / General discussions
    Last Post: 16th Jan 2011, 19:21
  3. VHS To DVD Recording errors
    By DuBsTaR in forum Newbie / General discussions
    Last Post: 14th May 2010, 12:31
  4. recording old VHS movies to DVD on LG RC389H
    By gorelle in forum Video Conversion
    Last Post: 28th Dec 2009, 01:14
  5. DVD-VHS Recorder Proplem with Recording
    By mactek in forum DVD & Blu-ray Players
    Last Post: 7th Nov 2008, 15:02
