Title says it all. What programs are suitable? Just wanna split the file into to two files and put each one on their own cd.
Thanks for all anwers.
Telcontar
You can use TMPGEnc to merge or split mpeg. Go to mpeg tools and click on "merge & cut" tag.
TMPGenc will do the trick use this guide
http://www.vcdhelp.com/edit.htm
som people have problems with it but give it a try. and read the problems at the bottom of the guide
Hope This Helps
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked?
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 7Last Post: 26th May 2012, 06:49 -
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 13:34 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 12:51 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 13:38
Statistics
Newest guides
Latest tool updates
New media comments
