VideoHelp.com Forum
  1. why I can see partially downloaded files in mpeg format, while avi files need to be downloaded completely?
    thanks
    Goomba
  2. I believe it's because some info might be stored within the file that gives its configuration to the player.... Don't know for sure but if you re-index the avi file using divxfix you will be able to see it. This just tells me that there must be some config info at the start that tells it how many indexes or frames to expect. By reindexing it you will be able to play the file....
    Look in the tool section here for the link to get divxfix.
    Hope this helps.
    -S
  3. thanks, I try it now
  4. Member spidey's Avatar
    Yes, it is due to Mpeg having headers so you can play a partial. For avi's, assuming you have the codecs installed, just open it in Virtual Dub and it will re-index the missing parts, and you can easily scan through it.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  1. Replies: 5
    Last Post: 19th Dec 2011, 16:42
  2. Replies: 7
    Last Post: 27th Jul 2011, 09:25
  3. Replies: 0
    Last Post: 3rd Jan 2011, 05:44
  4. Someone to fix partially deleted .MOV files
    By Zunder in forum Newbie / General discussions
    Last Post: 27th Sep 2010, 13:17
  5. Codec problems with downloaded avi files?
    By aelfheah in forum Video Conversion
    Last Post: 16th Jun 2007, 07:48
