VideoHelp.com Forum
  1. When I try load any avi file with avisynth script I just get blank green screen with no audio(same when loading in media player/virtual dub/tmpgenc)... Here is my script
    LoadPlugin("c:\avisynth\mpeg2dec.dll")
    LoadPlugin("c:\avisynth\decomb.dll")
    AviSource("C:\Program Files\Direct Connect\Received Files\jar-bhd2.divx.avi")
    ConvertToYUY2()
    Telecide(reverse=false,swap=false,firstlast=false, post=true,threshold=15,dthreshold=9,blend=true,chr oma=false,y0=0,y1=0)
    Decimate(cycle=5,mode=0,threshold=0)
    BilinearResize(448,254,6,0,564,240)
    TemporalSmoother(2,2)
    AddBorders(0,0,0,0)
    Even the simple AviSource behaves the same. Can somebody please tell me what the problem is...
  2. More info.
    I am using Avisynth 1.06 tried other versions too and am running windows xp...
    Can you play the avi with Win media player? I mean, did you install the proper divx codec? If a simple
    does not work, either you dont have the proper codec or did not install Avisynth properly.
  4. Thanks for the reply. I couldnt play even with simple avisource. ONce I replaced the divx5 codec wirth divx4 it works fine...
  1. Blank screen when playing video on 'full screen'
    By RAYPEV in forum Newbie / General discussions
    Last Post: 4th Aug 2011, 19:40
  2. Replies: 5
    Last Post: 6th Nov 2009, 21:06
  3. Underwater Green Screen
    By kccannon in forum Editing
    Last Post: 21st May 2009, 19:35
  4. Avisynth drops blank frames?
    By wfael in forum Editing
    Last Post: 9th Dec 2008, 22:06
  5. Screen turns green
    By boysha in forum Newbie / General discussions
    Last Post: 31st Dec 2007, 13:46
