Please advise urgently how to do the above,NOT using BE SWEET. Thanks
I once did just rename the Mp2 file to MPA files & the job worked fine afterwards. (Using Win On Cd creating a music album)
winamp, rtfm... same as wavout from mp3
FIEND,
Thank you for your quick reply.I cannot follow: I ran WINAMP, it is playing the mp2 file- how do I proceed from here to convert to wav file . Please be more specific
hey man, in winamp, goto options -> preferences and then under "plug-ins" goto "Output" and select "Nullsoft Disk Writer plug-in" and this will change whatever file you are playing with winamp to a .wav file, there you go, your question has been answered!
Luloo
Luloo,
Thank you.It worked.
i use a prog called "MP3_2_Wav". it also decodes .mp2's as well as .mp3's. you can select and decode more than one file at a time too.
8)I'm Speed Racer and I Like to Drive Fast!
You can also do it with TMPGEnc
Open your file in audio source, click file>output to file>wave file
5.1 audio question - is a single .wav file true 5.1 DTS?
By jazzsander in forum AudioReplies: 5Last Post: 18th Apr 2012, 21:00 -
Vegas 10: saving audio tracks to seperate .wav file
By Toastie in forum EditingReplies: 8Last Post: 6th Mar 2011, 21:50 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 04:14 -
Rescue WAV audio file
By Richard_G in forum AudioReplies: 8Last Post: 24th Sep 2008, 19:27 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52
