i need some help ripping dvds.i just started ripping dvds.ripped 1 so far.i went to rip another one and half way through disk cleanup popped up and said i ran out of space so it made me stop ripping.so i went to mt computer and clicked on c drive and it said i had 8.32 gigs left.even smartripper says i have enough space.so i went to try and rip the one i have already ripped and the same thing happend.also when i go click on drive space under system tools it says i only have a 2 gig drive when i know i have a 12 gig drive.does the drive space thing have anything to do with this?if so how do i fix this.
Thread: help!!!!!!!!!!!!1
reinstall
tried it.should i get a diffrent program.if so what program or should i get rid of disk cleanup and drive space.do i need them.do you think that wuoldhelp if i got rid of them
if its not really needed then i would toss it keep disk cleanup, but get rid of the other one.
Yu should run scandisk and defragment your harddrive to see if the space you say you have will show up. If you know you have enough space but when you click on the c drive it says you don't then you need to run system tools on your drive.
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
