i need help please, can i add subtitles to mpeg/vcd i encoded, what tools should i use, i searched every where without any success, thanx in advance
Thread: adding subtitles
Yes, you can add Subtitles, but i'd recommand you to do it from the start and not add ontop of a file, cause you'd need re-encoding.
Try checking the Complete (All-In-One) Guide v2.0 in the DVD RIP section, it shows how to add Subtitles in all sorts of ways.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Tools you can use
VirtualDub, framserver to TMPGEnc
Vobsub filters or Donald Graft ssa sub filter
You can get the ssa filter at http://sauron.mordor.net/dgraft/
Get the latest Nimo all-in-one codec, it has Vobsub filters for Virtual dub
If your subtitles are not in ssa or sub format you will need to source for a convertor (good luck if they are in SAMI format, I ve had lots of trouble converting them).
Cheers
thanx guys for your help, i found it easier to re-download avi and start from scratch
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
adding subtitles
By dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 22:27 -
Adding subtitles
By tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 00:39 -
Adding subtitles
By Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 13:43 -
Adding subtitles to a DVD
By RealTelstar in forum SubtitleReplies: 1Last Post: 28th Sep 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
