I'm getting a PocketPC pretty soon, and I need to know the best way to lower the quality of DivX movies so it will play on my Pocket PC with Pocket DivX.
I need to change the resolution to fit the small 240x320 screen. I would like to use VBR instead of CBR. Also I need to down-sample the audio to 64kbs joint-stereo to save space.
I tried doing all that with VirtualDub but I don't think I can do VBR. Also I can only choose stereo or mono for sound conversion, no joint stereo.
Any help here?
Try Vidomi It can use divx 3,4,5, and Xvid. With two pass (VBR) encoding.
I use it for my Dream Cast (which use Pocket Divx Player) with 320x240 29.976 fps 48kbit dualchannel audio at 44hz. With bitrates between 700 and 200.
all ya have to do is use virtual dub and add a resize filter to whatever resolution you want and ya can encode the audio also
how do I convert .divx files to .avi without loss in quality
By Onceler2 in forum Video ConversionReplies: 2Last Post: 17th Oct 2009, 10:03 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video StreamingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 00:43 -
Convert .h264 to divx/xvid or dvd success with slightly lower quality.
By Edgelessdiamond in forum Video ConversionReplies: 13Last Post: 26th Apr 2008, 21:21 -
how to convert mkv to divx/avi without loosing its quality?
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2007, 11:00
Statistics
Newest guides
Latest tool updates
New media comments
