Hi
I have converted four SVCD´s to DVD format using Ulead Movia Factory. Now I want them to play "in a row" as one movie. Is that possible using Ulead MoviFactory? I have seen the option where it makes multiple files to one, but I am afraid that the sound will go out of sync. Does anyone have expreince with the above? Any help will be appreciated
Claus![]()
Yes, Ulead DVD Movie Factory (Stand-Alone and Plug-In) will run all clips together - even if they are not joined as a single file. However, if they are not joined as a single file, you will get a thumbnail for each clip in the menu (Personally - I don't like this.)
I have used Roxio Video Pack (They can keep it - I returned it for a refund); Ulead DVD Movie Factory (too simplistic for my tastes) Pinnacle Express (Similar to Movie Factory, but a tad nicer - especially if you use Pinnacle Studio to edit with!, but still a little too simplistic)
I also have used DVDiT! LE and Pro - I REALLY don't care for the interface and total lack of features - but they both offer WAY more control than those previousely mentioned (except Video Pack)
The *BEST* (in my experience) for quality, control and output is Ulead DVD Workshop. Flawless DVDs made and the control and navigation set-up is awesome.
Pinnacle Express has a great interface and would be my second choice. They are releasing a 1.1 update soon - hopefully adding a little more feature.
I know this is a verbose message, but I figured answerring one question would lead to another and so on.
All the DVD authoring software I have mentioned will default to playing all clips in-line unless you specifically set-up navigation to return to a menu after that clip plays. These would be Video Pack, DVDiT (LE and PRO) and DVD Workshop.
Oh, and nothing says you HAVE to have a menu at all.
Hope this is insightful for you.
Ipsissima Verba
I have used dvdmf with multiple mpgs. for dvd I just added them one after another and did not create any menu or chapters.After it burned to my ao4 pioneer -r .I load the dvd and press play,it plays them one after another with about a one second gap inbetween each one.The chapter button on the dvd player works to select what mpg you want.Let me know if you are able to eliminate the 1 sec. gap.I haven,t tried to create chapters yet because they are automatically made to my surprise.I have been playing the dvds on a Apex ad-1500 and dont know if the chapter thing works on all players .Good luck. :P
[quote="mcmacky"]
I have tried that now but I have huge audio sync in the 2nd and 3rd mpg.
thanx anyway for your help.
Ulead Moviefactory 6 transition Help
By musickerns in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2011, 13:26 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 04:05 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 10:46
Statistics
Newest guides
Latest tool updates
New media comments
