hi can somebody help me im new, can someone tell me how to turn a divx into a vcd?
step by step or show me a place that would have a guide?
can i play a vcd on a home dvd player, not a pc?
please help me
thanx
Results 1 to 12 of 12
read the how to, it will tell you alot about encoding
where is the howto
It's on the left in green under "convert."
ive tryed it and i did everything and it wont encode is there anything else?
If you followed the guide from here and it won't encode then you either have done something wrong or your DivX file is corrupted. The guide here works fine. I've used it and so have countless others. A few questions that might shed some light are: Can you watch your DivX on your computer? Is the file complete? What steps (tell us) did you use to encode?
Ok, when you say that the guide didn't work, what's the actually part that didn't work? Can you play the DivX file in media player? Was TMPGenc able to read the file? Could you generate a MPEG1 file? Could you play the MPEG file in media player? Could you burn the MPEG1 file? If so how? Is it that your DVD couldn't read play the VCD? etc. etc. Give us some more info
Other guides to look at are:
http://www.vcdhelp.com http://www.doom9.org and http://www.flexion.org/vcd
flexion has a lot of screen shots and step-by-step instructions so you might want to check it out.
@vejita-sama...i see you're in seattle...i'm in olympia..
in the program it doesnot encode it says that file canot be created . i downloaded this file from yoink. it plays on my media player, but on my dvd it says no disk i know my dvd player plays vcd cause it says it on the front . the file is not a whole movier im using it so i can experiment on it
I wonder if you need an smr patch...
my suggestion is to check to see what type of disks your player will play by checking the dvd players list here: http://www.vcdhelp.com/dvdplayers.php
you then need to convert the divx to a vcd compliant mpeg using tmpgenc. once that is done, you need to use nero to burn the video cd onto a cd-rw. this may be a round-about way of doing things, but it works for me - why fix what's not broke?
but check to see if your player can even play burned vcd's first. otherwise none of the help people are offering here will matter.
hope this helps... one (improving) newbie to another.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 22:00 -
I am looking for a good priced upscaling hdmi dvd player mulitregion+dvix
By edmond in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Mar 2008, 08:22 -
Getting 2gig Dvix files on a Standalone dvd player
By clevername2000 in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2007, 02:22 -
is possible to burn HD video to a DVD and play it on a normal DVD player?
By kozmo62 in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 16th Jul 2007, 12:54
