I use SmartRipper. After ripping, I notice the images that are in a moving mode have continuous horizontal breakup. Kinda like it was pieced offset on every other couple of lines. This only happens during action movement.
What's the solution?
did you frameserve in dvd2avi, and if you did, did you have forcefilm checked ?
Mikerios, you wrote = did you frameserve in dvd2avi, and if you did, did you have forcefilm checked ?
Where do I find the sections in the program you mentioned in the above?
i'm assuming you have dvd2avi already...
load the vobs into dvd2avi, then preview it (f5) and tell me which the info box sex about video type (is it FILM, progressive or NTSC, interlaced?)
i'm guessing the particular dvd u just ripped is NTSC, interlaced
i'm assuming you have dvd2avi already... NOPE
load the vobs into dvd2avi, then preview it (f5) and tell me which the info box sex about video type (is it FILM, progressive or NTSC, interlaced?) ....IT'S NTSC The INTERLACED you asked about...I don't see wording or a place with that available to change.
The SmartRipper looks like a clean rip, but then I take it to a program called DVDx to encode to MPEG2 (Super Video CD), NTSC 29.97fps (480x480).[/b]
is there a setting for field order anywhere in the encoder?
you may need to reverse the field order
Horizontal Tearing
By Tripledrop in forum Software PlayingReplies: 0Last Post: 16th Mar 2011, 12:57 -
Breakup a huge mkv file into smaller pieces
By mysts in forum Video ConversionReplies: 7Last Post: 3rd May 2009, 14:34 -
video breakup and glitch detection software
By Zone3 in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2009, 21:22 -
AMD breakup; chip production now to be Arab-owned
By ahhaa in forum ComputerReplies: 8Last Post: 8th Oct 2008, 21:53 -
Audio Breakup
By Sooner02 in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 23rd May 2007, 11:47
