hi,
when capturing with my wintv card using virtual dub newest version.
using the hufuyff [ or something like that ,,,ya kno] codec.
it stops at 4 gigs....... now i was already told about this.
but the 4gig movie it creates is unplayble. it wont play it n gives me an error
n i tried resaving it using vdub as listed on this site but its same story
any ideas?
perhaps what causes it or how i can make captures that are playeble
and while at it perhaps a way to capture more then 4gigs using 1 harddrive?
thanks alor in advance
Mid
Thread: Help capturing with vdub
Properly you're using Win9x or WinME. They only use FAT(32). If you've got W2k or Wxp, be sure you use a NTFS partition for the captures.
Your problem is caused because FAT32 only allowes AVI-files of maximum 2Gb. It allowes you to 'override' this 2Gb to a top of 4Gb, but then your avi's will be corrupted.
To solve this, install w2k/wxp so you have the ability of ntfs, otherwise you must use the option of segmented capturing inside of VDub. This way, VDub will automaticly create multiple files for your captures of a maximum of a particulary size (decided by you, I suggest to use the default of 2Gb avi's). When file.00.avi is opened in VDub, VDub will automaticly search/open for all other files, so you can operate at them if were it 1 big file.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum CapturingReplies: 0Last Post: 10th Jan 2012, 19:06 -
Problems capturing HDMI with AVerTV CaptureHD/-H727 and VDub
By Gwar in forum CapturingReplies: 5Last Post: 12th Sep 2011, 19:00 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 8th Feb 2010, 20:50 -
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 10:39 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 06:40
Statistics
Newest guides
Latest tool updates
New media comments
