VideoHelp.com Forum
  1. Hi there I am a complete newbie, I was trying to make a vcd of some
    mpeg files on my pc.
    I added them ok, then clicked "Go", and it created the image ok, but then
    I got an error:
    "Error No Driver found for "IDE-CDR/RW (Try to use Force Driver in the
    CDRDAO settings page)
    What does it mean I have no driver, I burn cds all the time.
    I went to System on my pc, and looked at my cdr driver section, and sure enough it says "No driver have been loaded or are required for this device"
    I did a search for a better driver, and it finished and said the best one was already loaded, its location is:
    C:\WINDOWS\INF\MSCDROM.INF
    Can anyone help me? Where can I get drivers from?
    Also on a different note, what is ASPI? And why "does it not seem valid" on my pc (from VCDEASY)
    Many thanks!!
  2. Ok, I tried it again, and it made a BIN file, and XML file, and a .cue file
    What do I do with these, do I just burn them to a cd with easycd or something?
    Or do I have to do something else?
    PLease help me someone......
    check the guides on the left...
    open nero or whatever you use, and burn image--load the .cue file.
    that's it.
  4. if anyone is interested here is the errors from the first go:
    I got then on the second go too, but the bin files etc were created ok
    ERROR: No driver found for 'IDE-CD R/RW 8x4x32' (Try to use "Force Driver" in the "CDRDAO settings" page, with 'generic-mmc' for example)
    ERROR: Cannot setup device 1,1,0.
  5. Go here for help on all the programs that support Cue/Bin files:
    http://www.digital-digest.com/dvd/ar...cd/start5.html
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  6. just burn the image? what image, and how do I load the .cue file
    I dont have nero, I have clone cd and direct cd.
    I tried to install nero but it wouldnt let me.
    Could you elaborate for me, is the image file the .bin file?
  7. The CUE/BIN image is the combination of both the CUE file and the BIN file.
    The BIN file contains the data, while the CUE file tells the burning proggy how the data in the BIN file is organised.
    To load/burn a CUE/BIN image, you will have to use a program that recognises the format and load the CUE file.
    http://www.vcdimager.org/guides/burn...in_images.html
    You can't use the included CDRDAO burning proggy with VCD Easy because you don't have an ASPI layer installed. You can install this by downloading "ForceASPI" from http://www.doom9.net It will probably work after that.
    You cannot burn CUE/BIN images with CloneCD or DirectCD.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  8. Download cdrwin. theres a free demo that lets u burn at 1x. Just load the cue sheet in there and burn
  1. Hardsubs Easy
    By kazz0817 in forum Subtitle
    Last Post: 22nd Jan 2011, 04:44
  2. Replies: 4
    Last Post: 18th Dec 2010, 11:57
  3. Is there any easy way
    By kemcel in forum Media
    Last Post: 17th Mar 2009, 08:07
  4. VCD Easy
    By kshavo in forum Authoring (VCD/SVCD)
    Last Post: 12th Feb 2008, 14:43
  5. need a easy to use subtitle program
    By cowboysroy31 in forum Subtitle
    Last Post: 7th Sep 2007, 22:30
