can tmpg convert an image sequnce to an mpeg...if not are there any encoders that can?
Thread: Image Sequence
I believe that Virtual Dub can take a series of stills and make an AVI out of them using Donald Graft's "Logo" filter (grab the filter from one of the links at virtualdub.org) - frameserve that to to your mpeg encoder. I have also converted a series of stills to an AVI using Paint Shop Pro's accesory, Animation Shop Pro (then encoded the AVI to an mpeg with tmpgenc).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Yes TMPGEnc can take an image sequence and convert to MPG, just load up the first BMP or JPG in the video part of TMPG and hit start.
Thanks Shabubu,
That was very easy, just so you know I needed to cconvert a QT movie to MPEG-1 and it worked like a treat.
Thanks Man! :D
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 11Last Post: 16th Mar 2012, 12:58 -
Converting .MTS to a .JPG image sequence?
By Krynj in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 21:14 -
CLI batch Vdub Image Sequence
By corsiva in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 12:49 -
Image sequence and easy x264 GUI
By Bucic in forum EditingReplies: 5Last Post: 4th Oct 2010, 16:03 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 09:17
Statistics
Newest guides
Latest tool updates
New media comments
