The person didn't bother to deinterlace this at all and later resized it. I've found that resizing vertical resolution to 328 largely mitigates the moire pattern and makes it deinterlaceable but I still get ghosting effects. What's the best way to fix this?
The original field structure has been screwed up so a normal inverse telecine won't work. Try something along the lines of this in AviSynth:
Code:Blur(0.0, 1.0) # blur away most of the comb artifacts vinverse() # blur more comb artifacts FixBlendIVTC() # remove blending TDecimate() # remove duplicate frames Sharpen(0.0, 0.7) # resharpen the picture a bit
Thanks a lot jagabo, I didn't know about fixblendIVTC before. Your script works a lot better than mine not to mention faster.
Code:#AssumeTFF() #lanczosresize(720,328) #QTGMC(preset="medium") #lanczosresize(720,404) #Selectevery(2,0) #TDecimate
Thanks again.
Deinterlace where?
By newpball in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd May 2015, 13:55 -
Deinterlace
By bartonjd in forum DVD RippingReplies: 5Last Post: 27th Feb 2015, 14:03 -
how to deinterlace in most appropriate way?
By baunduley in forum Newbie / General discussionsReplies: 26Last Post: 17th Sep 2013, 17:46 -
Not sure how to deinterlace this?
By mmbwdpnz in forum Newbie / General discussionsReplies: 8Last Post: 22nd Feb 2013, 03:41 -
Trying to deinterlace properly
By Marc05 in forum DVD RippingReplies: 7Last Post: 11th May 2012, 10:59
