Hello,
I'm using Icaros for a long time now and really love it!
But since Windows 10 1607 "Upgrade" I've got some really nasty Problems while watching videos. I tried everything including fully reinstalling Windows but its still there. It happens on 3 different Computers after installing Icaros. I Even fully reinstalled one, just to check whether it really just happens after using Icaros, and yes, it really seems to be Icaros.
It just happens with 1607. 1511 works perfectly fine. It happens with either MPC HC and VLC (both clean Installed). Haven't tried anything else.
Even after unInstalling Icaros the Bug remains!
The Problem: Its really hard to describe, but its like the Windows, or even the Taskbar behind the Video Player kind of shines through the Video while Playing. Its specify strong if the Windows behind is moving, for example if you are copying something and the Copy Windows is right behind the Video (like in the Video I posted).
Heres a Video: https://youtu.be/2pfYzeLuxO8
BTW. Sorry for my bad English!
Latest icaros ? 3.0.1
See also or ask in http://shark007.net/forum/Forum-Icaros-Development -
Try running the program under the windows 10 compatibility mode - https://support.microsoft.com/en-us/help/15078/windows-make-older-programs-compatible
[CLOSED] Windows Explorer erases folder instead of selected files
By El Heggunte in forum ComputerReplies: 2Last Post: 4th Jul 2016, 19:14 -
Yet another bug? :-P
By El Heggunte in forum FeedbackReplies: 9Last Post: 29th Oct 2014, 10:56 -
VLC Windows 8.1/8 Bug(MKV stuttering and lagging)
By pavjos777 in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2014, 15:30 -
Icaros, GREAT Explorer Files preview thumbnails presenter
By visible0 in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2013, 19:16 -
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 16:59
