Results 1 to 12 of 12
  1. i record a tv program from satellite receiver i want to simply cut from start and end positions, i don't want to change the format
    this is mediainfo log file
    General
    Complete name : F:\PVR\Hakodate, Japan - HD\NHK World TV HD(20170211_180546).TSV
    Format : MPEG-TS
    File size : 3.36 GiB
    Duration : 52 min 57 s
    Overall bit rate : 9 089 kb/s
    FileExtension_Invalid : ts m2t m2s m2ts m4t m4s ts tp trp
    Video
    Menu ID : 26 (0x1A)
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Bit rate : 8 543 kb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.165
    Stream size : 3.16 GiB (94%)
    Audio
    Menu ID : 26 (0x1A)
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Bit rate mode : Constant
    Bit rate : 96.0 kb/s
    Channel(s) : 1 channel
    Sampling rate : 48.0 kHz
    Compression mode : Lossy
    Delay relative to video : -573 ms
    Stream size : 36.4 MiB (1%)
    Language : English
    Menu
    Menu ID : 26 (0x1A)
    List : 1160 (0x488) (AVC) / 1120 (0x460) (MPEG Audio, English)
    Language : / English
    Jan 2007
    i use Video Redo to edit DVR recordings, its not free, but its good, it has stream Fix feature you can run before editing, to fix any glitches or time sync play back problems
    then use the time line editor, and mark what to cut and what to keep and save your file
  3. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    tsMuxeR is one possibility. Or maybe AVIDemux if you need more edit options. They are both freeware.
    And welcome to our forums.
  4. thanks for help, in tsMuxeR file not supported but AVIDemux awesome free software, its working very good. thanks
  5. i record a program from another channel but when i try to open with AVIDemux, (not working) message appear in top of the window,
    General
    Complete name : F:\PVR\BBC Earth(20170218_004527)\BBC Earth(20170218_004527).TSV
    Format : MPEG-TS
    File size : 2.76 GiB
    Duration : 59 min 10 s
    Overall bit rate : 6 684 kb/s
    Video
    Menu ID : 21 (0x15)
    Format : AVC
    Format profile : Main@L4
    Codec ID : 27
    Duration : 59 min 8 s
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Menu ID : 21 (0x15)
    Format : MPEG Audio
    Mode : Joint stereo
    Codec ID : 4
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Delay relative to video : -690 ms
    Stream size : 54.2 MiB (2%)
    Audio #2
    Menu ID : 21 (0x15)
    Format : MPEG Audio
    Codec ID : 4
    Audio #3
    Menu ID : 21 (0x15)
    Format : MPEG Audio
    Codec ID : 4
    Audio #4
    Menu ID : 21 (0x15)
    Format : MPEG Audio
    Codec ID : 4
    Text #1
    Menu ID : 21 (0x15)
    Format : DVB Subtitle
    Codec ID : 6
    Duration : 59 min 6 s
    Delay relative to video : 4 s 909 ms
    Language : Chinese
    Text #2
    Menu ID : 21 (0x15)
    Codec ID : 6
    Delay relative to video : 4 s 991 ms
    Language : Korean
    Text #3
    Menu ID : 21 (0x15)
    Codec ID : 6
    Delay relative to video : 4 s 953 ms
    Language : Indonesian
    Text #4
    Menu ID : 21 (0x15)
    Codec ID : 6
    Language : Malay
    Menu
    Menu ID : 21 (0x15)
    List : 2130 (0x852) (AVC) / 2131 (0x853) (MPEG Audio) / 2132 (0x854) (MPEG Audio) / 2133 (0x855) (MPEG Audio) / 2134 (0x856) (MPEG Audio) / 2140 (0x85C) (DVB Subtitle, Chinese) / 2141 (0x85D) (DVB Subtitle, Korean) / 2142 (0x85E) (DVB Subtitle, Indonesian) / 2143 (0x85F) (DVB Subtitle, Malay) / 2160 (0x870) (SCTE 35)
    Language : / / / / / Chinese / Korean / Indonesian / Malay
    Jan 2007
    Will it play on the pc in VLC or mpc
    If not it's encrypted or corrupt
    I do use avidemux for some things
    But I not sure it can handle something with that many audio and text streams
  7. Its not encrypted, VLC open it.
    by the way any way to open encrypted videos because many channels recordings not open on VLC but i want to record it.
    Jan 2007
    What are you recording on
    Any video recorded on the pc, you should be able to open
    Transferring from hard drive from satellite DVR encrypted, just forget it
    Will take the Nsa super computers to decrypt
  9. I record documentaries like from bbc earth, discovery science
    ok please tell me about my 2nd recording, its not encrypted, vlc open it, but AVIDemux not handle it,
  10. please tell me any other free cutter like AVIDemux
    Aug 2006
    TS streams recorded from over-the-air broadcast TV, satellite TV, or even cable TV can have missing frames and other errors. Free editors and the majority of paid editors can't handle these problems. I looked for a freeware solution for a long time before finally giving up and buying paid software. TSSniper was the best freeware I tried, but was still inadequate. It only cuts on I or IDR frames and is unable to deal with more than a few errors. I never tried TSSniper for editing H.264 streams but its specs include H.264.
    VideoReDo TVSuite and TSDoctor are paid editors designed to handle errors in recorded H.264 digital TV streams. TMPGEnc MPEG Smart Renderer 5 is another paid program that seems to work for some people.
    Ignore list: hello_hello, tried
