    Feb 2017
    India
    Dear Gurus,
    I have been being trying till the first AssFilterMod renderer came out, to work with but to no avail. So I just used XySubFilter instead, but it is no longer developed.
    Recently a new version of AssFilterMod came out with the "autoload" feature like XySub does, and I tried again with MPC-BE with Madvr as the renderer but it didnt work. Theres no subtitle display.
    Could you help me with integrating AssFilter + MPC-BE + madVR for subtitle display?
    Thank You.
    You could try install latest LAV Filters Megamix(released today). It includes assfiltermod and madvr and should configure it for you.
    Feb 2017
    India
    Is there any other way, I mean other than LavMegamix?
    Sent from my YU5010 using Tapatalk
  4. With the latest MPC-BE nightly AssFilterMod does not load here either. It loaded in an older version, though. Not sure if that's on purpose or a regression.
    Personally, I use a custom MPC-HC build that has AssFilterMod support. It hasn't been integrated into the vanilla MPC-BE and MPC-HC versions yet (though it can work but you cannot select it from the subtitle menus).
    Feb 2017
    India
    Thank you.
    Think I'll just have to wait. Maybe try LavMegamix later.
