Results 1 to 22 of 22
    Sep 2013
    Texas , USA
    Hello & Thanks ,
    I have a binaural .wav file that is apparently two channels but shows up in Audacity as one Track .
    When I open with VLC , I can mute Left or Right channels , but don't know how to split it into actual Left/Right tracks .
    Anyone know how to do this ?
    Thanks...Vern
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    In both Audacity and Adobe Audition it opens as a stereo track as per attached image
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
  3. Originally Posted by vmars316 View Post
    H
    Can you clarify - did you want to output 2 separate mono wavs, derived from each L and R channel ?
    If so , you can use eac3to or ffmpeg . eac3to will automatically label the channels in the output file name
    eac3to
    eac3to input.wav output.wavs
    ffmpeg
    ffmpeg -i input.wav -map_channel 0.0.0 left.wav -map_channel 0.0.1 right.wav
    IIRC, audacity can channel map too, so you should be able to specify it that way. Or even delete 1 channel, then export, then repeat for the other
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    If you want 2 separate wav files select 'split stereo track to mono' drop down menu within track details on left. Then Export multiple audio - done
    Sep 2013
    Texas , USA
    Thanks ,
    yes I know , but still shows as one track , two channels .
    How can I split off each channel as a separate track ?
  6. Code:
    ffmpeg -i stereo.wav -map_channel 0.0.0 left.wav -map_channel 0.0.1 right.wav
    ffmpeg -i stereo.wav -filter_complex "[0:0]pan=1c|c0=c0[left];[0:0]pan=1c|c0=c1[right]" -map "[left]" left.wav -map "[right]" right.wav
    https://trac.ffmpeg.org/wiki/AudioChannelManipulation
    After this you can do whatever you wish...
  7. If you use OcenAudio you can do it easily. Load the audio file. It will display as a musical note in the left panel.
    Right-click on it and a submenu will appear. Simply 'Extract Left Channel', repeat on original file and 'Extract Right Channel'.
    You will now have three files showing; the original, and the left & right separations.
    Right-click on each of these new files in turn and use 'Save As'. Save or transform, your choice.
    Hope that is easier for you.
  8. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Thanks ,
    I ntold you in my previous post
    Please read the help file so that you know where all the menu items are located......
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Here it is
    Sep 2013
    Texas , USA
    Thanks ,
    Yes , I did that and I get two identical tracks . Not what I want .
    In the wav file Each channel has only 1 tone .
    When I try your way I get two identical tracks . Not what I want .
    I want 1 tone on trackA and the other tone on trackB .
    Sep 2013
    Texas , USA
    OceanA gives me the same two tones on each track .
  12. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Thanks ,
    Then use simply use the option "split stereo track" located immediately above "split track to mono"
    Sep 2013
    Texas , USA
    netmask56 ,
    Thanks ,
    When I do that , it splits it , but no matter how I save it (wav or mp3) ,
    when I open saved-file , it again shows up as two-channels-onetrack .
    Is there a way so save it as two traacks ? Thanks
  14. Originally Posted by vmars316 View Post
    No it doesn't. The tones are very similar, I admit , but the separated tracks ARE the two tracks you want.
    They will be the same two tracks in Audacity or any other software you might use.
    Edit: I think I see. Pull FileA and FileB together into Audacity. You will have 2 tracks A+B, one above the other.
    netmask56 has already explained how to do it in Audacity alone. To be frank, you don't seem to be able to
    differentiate between the tracks you have separated, they are so similar.
    What is it you are trying to accomplish? Maybe someone can help by eliciting what it is you are trying to do.
  15. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    netmask56 ,
    Thanks ,
    So which menu item did you choose to save the files?
    Hopefully this one
    Aug 2010
    San Francisco, California
    What the OP wants are two monaural audio streams in a single file. But WAVE and MP3 files don't support multiple streams. They only support multiple channels. When apps like Audacity see a 2-channel WAVE, they assume it's stereo. You will have to use something like an m4a container to support multiple audio streams.
    Sep 2013
    Texas , USA
    Hello & Thanks All ,
    Audacity-1
    I think I can get what I want 'IF I can select only ONE track at a time in Audacity' .
    My thought is: I can create a single tone track mono , trackA .
    Then create a second single tone track mono , trackB .
    Open up another instance of Audacity-2 for good_morning.wav .
    Then 'IF I can select only ONE track at a time in Audacity ' ,
    Copy one track from Audacity-2 .
    Go back to Audacity-1 and Paste the Copied track into trackA .
    Then do the same for trackB .
    Of course it all depends on can I Select & Copy only one track in Audacity .
  18. Originally Posted by vmars316 View Post
    Of course it all depends on can I Select & Copy only one track in Audacity.
    http://manual.audacityteam.org/man/audacity_selection.html#track_mouse
  19. split stereo track to mono
    delete one track
    export
    undo delete
    delete other track
    export
    Sep 2013
    Texas , USA
    raffriff42 & jagabo , Thanks ,
    Got just what needed .
    Except that now I need to find a .* file type that can handle both tracks .
    It seems they all warn that they will merge both tracks into one track . ??
    What file type can I use ?
  21. Originally Posted by vmars316 View Post
    MOV is one:
    ffmpeg -i "1.wav" -i "2.wav" -map 0 -map 1 -c:a copy "2streams.mov"
  22. MKV is another.
